Clearing Error Codes
   / Clearing Error Codes #1
Broken Barbed L
XR 4140
I own an XR 4140 and recently started getting an error code of F 08. I tried looking it up but unable to find it anywhere. Is anyone familiar with this code and can anyone tell me how to clear the code? I have talked to my local dealer and received zero help.
Thank you
   / Clearing Error Codes #2
My book (for the XR4145) shows that code as S27 F08 - EGR Position Control Fault
   / Clearing Error Codes #3
I just ran into the same codes. Baling hay and tractor XR4145 went into regen. Kept baling and it completed the regen (I think) then lost power and threw the S27 F08 codes. So the EGR fault seems reasonable. What to do about it??? Any ideas or info in your manual? Guess I should purchase the repair manual.
Thanks,
Eddie
   / Clearing Error Codes #4
Check the wires going to the EGR valve, if a plug in connector, unplug and plug in a couple times. Might be able to ohm out the wires and see if there is an open across the sensor wires which would indicate a bad EGR valve.
Try removing the EGR valve and see if you can clean it with brake cleaner.
Replace the EGR Valve
2011 CATERPILLAR M318D MOBILE EXCAVATOR (A51242)
2011 CATERPILLAR...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50322)
2018 Toro Grounds...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
2023 KAWASAKI MULE (A51243)
2023 KAWASAKI MULE...
71050 (A49346)
71050 (A49346)
(10) 24' CORRAL PANELS (A51243)
(10) 24' CORRAL...
