Clearing Eastern Red Cedar Trees from 12 acres
   / Clearing Eastern Red Cedar Trees from 12 acres #1
macecase
Bronze Member
Princeton, KS
1965 John Deere 3020 Diesel and 1975 John Deere 4630 Diesel
I have 12 acres of Eastern red cedar trees that need to be removed to create a cattle pasture. My thought is to attach a tree pincher to my skid steer (which I have available to borrow) and go through the pasture, clip the trees, pile them and then burn them.
I see this as somewhat of a waste. I figure there has to be some use for these trees.
Cutting them down and milling them into lumber is not an option because they are not large enough. I estimate their age to be between eight and 12 years old.
I am very interested in suggestions on what to do with these trees. Or, if the only option is to cut them down and burned them, any suggestions on how to make that as quick and easy of a process as possible.
Thank you for watching and for your suggestions. Remember, mow your pastures so the eastern red Cedar tree does not take them over!
   / Clearing Eastern Red Cedar Trees from 12 acres #3
I don't think the young cedars have any economic value other than as Christmas trees.;) A skid-steer mulcher would make quick work of clearing the acreage.
Steve
   / Clearing Eastern Red Cedar Trees from 12 acres #4
Fence post or stay's are very common in Texas, last along time. Cedar are easy to push with an FEL, roots and all, very shallow.
What is an FEL?
   / Clearing Eastern Red Cedar Trees from 12 acres #6
What is an FEL?
FEL= Front End Loader.. all of those trees are ripe for pushing over with a FEL. Just the right size. Wait a day or 2 after a rain, and go to town. Gets roots and all, and no stump. Just push into the tree, and get sharp edge of your bucket hooked in the bark, and then lift, curl and push all at the same time. Plop, out they come.. Hydrostat transmission makes this easy without slipping a clutch, and wearing it out. Heck you might be able to charge local tractor owners to come and pop out the trees! In a Tom Sawyer fence painting kind of way!:laughing:
   / Clearing Eastern Red Cedar Trees from 12 acres #7
The comment about pushing them over is true. If you've got bucket teeth, you could hit the tree low at a dumping angle and they typically will pop right over. Then back up and push the root ball and the other side's roots will come out. My FEL w/o bucket teeth worked well.
I know some wildlife fisheries lakes like to sink cedars for fish habitat. Not sure about ideas of being profitable. The cedar eating job is lucrative. Oklahoma has a registry of cedar tree owners that are willing to let the harvesters come in and eradicate them on your property...see link below.
http://www.forestry.ok.gov/ercregistry
Sent from my Motorola Moto X using TractorByNet
   / Clearing Eastern Red Cedar Trees from 12 acres #8
Want to be carefull on the amount of cedar you add to a pond, they will raise the acidity.
   / Clearing Eastern Red Cedar Trees from 12 acres #9
A large number of them could be bush hogged. I know you can't do it with a light duty or even med duty hog but many or most could be done with a heavy hog and a good tractor. We used to hog down anything we could ride down with a ford jubilee. It would be faster than pushing by a good bit and you don't have to pile and burn.
2015 FORD F-350 (A45333)
2015 FORD F-350...
2003 PETERBILT 379 CRANE TRUCK (A45333)
2003 PETERBILT 379...
2022 Kubota RTV-XG850 4x4 Utility Cart (A42744)
2022 Kubota...
2008 Ford F-150 4x4 Extended Cab Pickup Truck (A42744)
2008 Ford F-150...
14' BI PARTING GATES W/ DEER ARTWORK, (UNUSED) (A40519)
14' BI PARTING...
2013 PROCO KILL TRAILER (A45046)
2013 PROCO KILL...
