clearing deep woods
   / clearing deep woods #1
dottieskipper
Lowndesboro, AL
John Deere 2014
We are using spray to kill overabundance of wild privet hedge, trying to get to the deeper woods to clean between trees. Unfortunately, there are many huge trees/limbs (2-6'diameter) laying on a steep incline (spread out) that need to be burned, in the midst of the trees. Can I do this, with hard woods around, without having too much heat produced? need advise--the county agent was clueless and everyone else wants big money.
   / clearing deep woods #2
You have not described how big an area you are dealing with.
You will have to skid out the downed trees with your Deere, then burn them in the open.
Be sure to elevate end of timber at tractor end, so it does not hang up on a boulder or other type of impediment, causing the tractor to rotate/pivot on rear tires to vertical in one second. I have experienced this exciting event personally, once, never want to again.
   / clearing deep woods #3
Do not even think about burning in the woods.
   / clearing deep woods #4
Unless you have a desire for making the national news as a forest fire!
And how big is a "John Deere 2014"? Tractor data doesn't list a model 2014.
   / clearing deep woods #7
Can you get a chipper back there, then you can just grind them up and leave them to rot.
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
AT 26in x 11-12in (A52377)
AT 26in x 11-12in...
2013 Bobcat T180 (A47477)
2013 Bobcat T180...
1987 Ravens 45 ft. T/A Float Trailer (A53117)
1987 Ravens 45 ft...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A55301)
Case Wheels for...
