Cleaning up new hoses
   / Cleaning up new hoses #1
picker77
Central Oklahoma
JD 3032E, dual remotes, TnT, tooth bar, grapple
Maybe everybody else already knows this, but I'm a newbie to hydraulics, so here's my story:
Had a couple of new 38" hoses made up at a JD dealership the other day, and when I got them home, just as a precaution I filled them each about 1/2 full of diesel fuel, sloshed them around a while and drained them into a paper towel, then blew them out good with air. I did this on the advice of an experienced hydraulics shop guy I know. He recommended using diesel fuel for rinsing, and cautioned me never to put alcohol, lacquer thinner, gasoline, or any other volatile liquid in a hydraulic hose--apparently that will dry out the rubber and contribute to future cracks or something. Sounded logical to me. Anyway, I wish I had taken a photo of the black rubber crumbs and crud that came out of one of them, probably more than a teaspoon full. I suppose it was residue from whatever method they used to cut the new hose (a cutoff wheel?). The other hose was clean as a whistle-go figure.
So before you slap on those new hoses you just got, rinse and blow them out good. Otherwise, you might end up with nasty stuff in your cylinders, valves, or filter!
   / Cleaning up new hoses #2
Yes, that is a good practice for sure. Good hose shops will clean them after assembly.
   / Cleaning up new hoses #3
The newish ultra thin cutoff wheels (5"x1mm) are good for keeping the muck to a minimum and as a bonus they seem to fray the wire braid less.
But yes it would still be a good idea to rinse the hose out - I think I usually remember.
I've used petrol, probably ok if they'll have oil in them soon.
   / Cleaning up new hoses #4
If the proper blade is used the contaminants are minimal...
Cut-Off Blades, LLC
.Abrasive wheels do work but need cleaning afterward.....But it's a good practice to always clean......:thumbsup:
2006 Silver Star 8'x102" 5 Horse Trailer (A50123)
2006 Silver Star...
2011 Homesteader Box Trailer, 6'x10' (A52384)
2011 Homesteader...
2025 Swict 66in Bucket Skid Steer Attachment (A51691)
2025 Swict 66in...
200887 (A52705)
200887 (A52705)
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A53473)
2012 JOHN DEERE...
