Cleaning the engine
   / Cleaning the engine #1
nhman
Virginia
Kubota B2910
Any recommendations for cleaning the engine and engine compartment? After the first summer of use the engine compartment and engine are dirty and dusty. I would like to clean it up. Can you use engine cleaner and a hose??
nhman
   / Cleaning the engine #2
All I do slide a can down over the exhuast pipe and tie wrap a plastic bag around the air intake before washing,than useing a mild dish washing liquid w/the pressure washer set low I began cleaning..I also use heavy cloth for those extra dirty places.
Once done and looking good its the air compressor turn to blow dry the engine etc..just be careful around the electric areas,for may want to protect them as well when washing.
At one time you could purchase a spray can of engine cleaner..foam..that was a pain to use if you had a fel to work around. /w3tcompact/icons/frown.gif
   / Cleaning the engine #3
Your going to think i'm crazy but this works. get some DOW bathroom cleaner, it has to be DOW. you know the scrubbing bubbles. spray it on and wait oh 5 to 10 minutes. then hose it off. best degreaser in a can. i learned from a used car dealer. that is how they made those high mileage greasy engines clean. my trucks engine has 157,000 plus miles on it and clean as a pin. try it and see for yourself.
I also will use mineral spirits with a engine cleaner attachment hooked to my compressor. but the dow method works better. on real dirty engines it may take two apps. i also like to spray wd 40 on my atv's and will do it to my tractor. makes it look good and new. and it helps when you wash it again to get the dirt off.
   / Cleaning the engine #4
the best way is NOT to let i get real dirtty to begin with, by this i mean clean it every so often, i usually just wipe it off, but u can spray it clean, just make sure it is a cold engine, and u don't use a very high spray around electrical system.
   / Cleaning the engine #5
I would be very cautious cleaning the engine. Nothing good can come of that in my personal experience. But I guess if you’re careful.
Does everybody do this.. It never even crossed my mind. Not to be belligerent, but it is just a tool. My thoughts are that the number one concern is proper operation and long life. Neither of these are effected by some greasy grime on the engine (are they?).
Water can contaminate the oil, electrical or bearings,… different cleansers can remove protectant coatings and encourage corrosion.
I’m probably be paranoid (or lazy /w3tcompact/icons/grin.gif ) but that’s my thoughts.
   / Cleaning the engine #6
I use Castrol Super Clean. It melts a lot of the oily deposits, and a little scrubbing with an old paintbrush gets the rest. I keep a couple of those plastic spray bottles with the trigger pump in the garage. One has full-strength Super Clean and it gets a lot of use on tires, engines and almost anything else that gets a lot of crud. My pickup is white, and the lower body gets a shot when I do the tires.
Another has a diluted mix of Turtle Wax Wash ( or whatever the 'mart has on sale). The bottle needs to have the soap diluted so it will go through the pump. To wash vehicles, I just wet them down, spray the diluted soap all over it, and scrub them with a really soft-bristled brush. The last couple years I have used one of those California Water Blades in lieu of a chamois most of the time...................chim
   / Cleaning the engine #7
Rogue, I'm at exactly the opposite end of the spectrum from you./w3tcompact/icons/laugh.gif I don't disagree that some cleansers and solvents could cause problems, but I've been washing the engines on my cars, pickups, tractors, lawnmowers, etc. for well over 40 years, sometimes with plain water and garden hose, sometimes, when necessary, using degreasers, sometimes using a hydro blaster (hook up both water hose and air hose to the gun), and sometimes using the pressure washers at coin operated car washes. And I take almost no precautions except to not spray water directly into the air intake. And then, after washing, I always run the engine long enough to get it thoroughly warmed up and to evaporate any moisture. I'm not recommending my methods to anyone else; just telling you what I do personally. I don't like a dirty engine 'cause I might have to work on it someday./w3tcompact/icons/wink.gif
   / Cleaning the engine #8
I agree with you, I have used Dow Scrubbing Bubbles on Cars, Motorcycles, Marine Diesel engines and now my Kubota BX2200, great stuff, works better than most degreasers and if you don't get it off before it dries, no problem, just wash it off later.
   / Cleaning the engine #9
This past Summer, I used Orange Blast (from Wall Mart). Comes in a pump-sprayer. Eats right through the grease and grime. Hosed it off with a regular garden hose (no pressure-wash needed). Smells just like oranges and matches my Kubota's color!
   / Cleaning the engine #10
Bird's method is pretty much the way I do it, too. Except, I haven't found the need to use chemicals. The pressure washer is a great invention. Just faucet water through the pressure washer cleans all the grease, crud, oil and dust I've encountered on an engine...and it does make the engine much nicer to work on!
OkieG
2012 Nissan Maxima Sedan (A51694)
2012 Nissan Maxima...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
Miller and Smith PNR-1000 Pull-Behind Proof Roller Trailer (A52377)
Miller and Smith...
2012 Ram 3500 Crew Cab Flat Bed Truck (A53422)
2012 Ram 3500 Crew...
1979 Clark C500-50 4,450lbs Propane Forklift (A51691)
1979 Clark C500-50...
