Cleaning stained asphalt shingles
   / Cleaning stained asphalt shingles #1
saw_dust
Bronze Member
There are companys in Florida/Georgia etc. that apply chemicals to remove the stains on asphalt shingles,and rinse the fungi off with a garden hose,has anyone on this forum had any experience with cleaning asphalt shingles?These stains are caused by an airborne spore that survives in high humidity areas and feeds off of the asphalt in the shingles I have read about some of these chemicals...Shingle Shield/American Roof Brite/Shingle Care to name a few...care to comment please ?
   / Cleaning stained asphalt shingles #2
If the stains are from a fungi (growing) then a simple mixture using chlorine bleach should do the job. Another way is to put a galvanized (or copper) strip at the peak (ridge) of the roof. The residue from the metal will keep the roof clean (normally). Look for barns that have galvanized cupalo's or vents, and you will likely see a clean streak immediately below them on the roofing.
I have read about the zinc strips and I have read that the chlorine damages the shingles....but could be a sales pitch to get you to buy the so called Shingle cleaning chemicals...
2007 CATERPILLAR D5GXL CRAWLER DOZER (A51406)
2007 CATERPILLAR...
2022 JCB 3TS-8T Teleskid Loader with Telescopic Boom, DB84 Dirt Bucket and FAE Forestry Mulcher (A53473)
2022 JCB 3TS-8T...
Light Tower (A52377)
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
