It turns out to be quite easy...just did that! With a small fine tip screw driver gently pry the edges of the plastic and it'll pop right up. If you are careful the wires connected to the switch will come too...but if they slip off no big deal, take the intake screen cover underneath completely off to get access from underneath the dash. Very easy to re-attach. Now to test the connection by jumping the wires to see if the lights come on...if yes than its the switch...if nothing happens with key on (careful not to ground wires out to the frame) than it might be the fuse that is located right above the battery. The switch itself is easy to repair. On a clean surface gently pry the snaps that hold the two parts together...careful as you separate the top from the bottom as the parts inside come flying out pretty easily. Just don't loose em! Water gets down into contacts and needs to be removed and sanded lightly to clean with very fine grit sandpaper. Inside switch are only 3 parts,1. a fine spring that fits under under the 2.contact pin that fits into the top...and 3. the small copper rocker contact plate. Clean and dry the inside of the switch. Replace clean dry copper rocker plate...goes in only one way, bent side down toward the cleaned contact point carefull to mount the small wings onto braces inside switch...if you look closely at the switch you will figure it out. Put a little dielectric grease inside spring holder so that **** little rocker pin stays put as try to carefully snap the two parts together...actually...thats the tricky part!
