CLEANING GREASE?
   / CLEANING GREASE? #1
dkf1998
Maine
New Holland TC40DA, John Deere Model L
Any ideas on removing the excess grease from around the joints after it builds up. What I usually do is remove the bulk with a plastic putty knife and then use a rag to finish it off, but it is very time consuming. I'm looking for some ideas.
   / CLEANING GREASE? #2
I used to clean it too. But now I just ignore it most of the time. Once a while I wipe it with shop paper towels.
   / CLEANING GREASE? #3
I'll give you the same advice I received, wipe it of with a rag, clean it with a rag with some mineral spirits. I don't like to let it build up as dirt sticks to it and could work it's way back into the joint besides grease gets all over everything.
   / CLEANING GREASE? #5
I use a pressure washer occasionally (about once every year or two )to get off the build up grease and hose off the dirt from the tractor at the same time. Of course afterward I have to wipe up the grease from the tractor where the pressure washer blew it all over. After I have cleaned up everything, I grease it well to drive out any water.
Of course nothing would beat a high pressure steam cleaner for degreasing but not many folks can afford one of those.
Usually I just wipe it of with a paper towel to remove the globs from over greasing and let the rest stay in place. WD 40 is about as good a solvent to remove grease from painted surfaces as you can get and doesn't require washing to remove the residue. A little dust will stick to it but that then wipes off easily also.
   / CLEANING GREASE?
Thanks for the replies. I will try the WD40, someone also told me to try Simple Green.
   / CLEANING GREASE? #7
how does all this heavy machinery that is slobbering grease out of every joint, working in the dust/sand/grit/dirt 12+ hours a day make it 20k hrs without worrying about wiping off greased joints?
   / CLEANING GREASE? #8
I don't bother cleaning up the excess grease. Tractor gets greased and washed almost every time I use it in Summer. i clean the grease off the nipples and then pump away.
   / CLEANING GREASE? #9
Except for the washed part, That is pretty much how I do it also, but must occasionally clean some of the globs off with my shirt when leaning against the tractor looking at something. Then I get pissed and blast it all off. During summer I wear just white T shirts and the FEL grease on them keeps me in shop rags most of the time.
   / CLEANING GREASE? #10
Oh how I have ticked my wife off so many times. Hop on the tractor after work to do something and not take the time to change into old clothes. Not that it ruined the shirt but as much as the greasy nice shirt got washed with all the other nice shirts.
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
(APPROX 20) 3" X 4" X 21 7/8" TUBING (A51247)
(APPROX 20) 3" X...
2015 JOHN DEERE 310K BACKHOE (A51406)
2015 JOHN DEERE...
