Cleaning Garage Floor
/ Cleaning Garage Floor #1
TNhobbyfarmer
Veteran Member
Middle Tennessee
Kubota L3430 Polaris Ranger 500
My house is about 15 yrs. old. My concrete garage floor has a lot of grease, dirt, oil and grime on it from years of neglect. My springtime project is to clean and paint it. Simple question.....how is the best way to clean it prior to painting?
/ Cleaning Garage Floor #2
Scrub and etch with muratic acid available at lowes or sherwin williams. Rinse and reduce first coat of paint by 50 percent with appropriate reducer, this will act as a stain/sealer. Then proceed with additional full strength coats.
Brad
/ Cleaning Garage Floor #3
How do you get all the "STUFF" out of the garage in order to clean it?
Eddie
/ Cleaning Garage Floor #4
Brad
I agree with bigshovel. Also, a lot of gargage floor paint kits sold at Lowe's and Home Depot will have little bags of the acid in them already. If memory serves me, not muriatic acid though, but something made from oranges, citric acid I think. It works though, I've used the latter.
For really tough stains, a pressure washer may need to be thrown into the mix.
Good luck and if you do decide to go with a kit, buy an extra box after calculating what the box says you'll need to do your garage floor...I learned that they are skimpy with it and you'll end up making an extra trip.
Podunk
/ Cleaning Garage Floor #5
For the first step in cleaning I have found the Castrol Superclean to be very effective on grease and oil. I wet the concrete, distribute the superclean with a sprayer, sweep it around mop style with attention to scrub the nasty spots, and then hose it all out.
Never liked a painted garage floor. Or any painted concrete for that matter.
/ Cleaning Garage Floor #6
I think the best directions on how to clean floor would be on product to be applied
I would degrease it first and maybe a second time just to be sure
/ Cleaning Garage Floor #7
Eddie
I agree. I would have to move everything to one side, do half and then do the other side, and even that would be a chore. Good luck.
/ Cleaning Garage Floor #8
Depends on how good of a job you want done on it.
Prep is everything in painting, shot blasting is ideal and costs about 50 cents per sq ft. Any of the acid etch's work, and usually clean with TSP prior to painting.
I use DuraGlaze epoxy from Porter.
I like the paint chip look, so on my basement we did a light gray, with blue, black and white paint chips. Instant coffee jar with large holes as a shaker.
Wear old golf shoes with spikes to work on the floor. You will need to go back across for "something" it just never fails.
Hmmm, sorry, got wandering but info thought you might want.
Best depends a lot on how much you want to spend.
Best is shot blasting / peening (let me know if you need a contact)
Next Hot high pressure, high quality soap, acid etch, TSP
Next, Cold pressure, degreasing soap, acid etch, TSP
Anything less, you will likely have a failure.
/ Cleaning Garage Floor #9
For smaller oil stains with lots of oil in them, like under where a dripping engine has parked for years, I have have very good results with paint thinner and cat litter.
Pout the paint thinner on and spread cat litter over it, when it is about half dry move it around with a push broom then wait for it to dry.
The paint thinner thins the oil, and the cat litter soaks up the mixture.
I have never been able to get really heavy oil stains out with water or acid based cleaners.
/ Cleaning Garage Floor #10
Make sure you remove anything that can rust before you use muriatic acid. Every thing steel or iron will be bright orange the next day. I think there are precautions concerning the fumes, too. Be careful out there!
/ Cleaning Garage Floor #11
Scgargoyle is right about the rust. I cleaned some stonework with muriatic and left some tools close by. Next day they were all rusted.
/ Cleaning Garage Floor #12
Hi
I myself install for dur-a-flex & Tnemec we do about 50,000 to 75,000 sf per year and all my floors are shot blasted.
Thats the best way to prep your floor to last for years to come.
Also try to use the Dur-a-Glaze epoxy for a good Anti-Slip go to lowes or homedepot and get a few bags of clean & dry sand and toss it in on for 2nd coat. We use about 3/4 lbs per SF.
Good luck
Ron.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
UNUSED WOLVERINE QMP1-16-6T QUICK ATTACH PLATE (A62131)
UNUSED WOLVERINE...
UNUSED ATS DJ2200 ELE. LIFTING MOTOR (A62131)
UNUSED ATS DJ2200...
2R FALLING PLOW (A62131)
2R FALLING PLOW...
2002 John Deere 737 Zero Turn (A63116)
2002 John Deere...
2016 BOBCAT T650 SKID STEER (A62129)
2016 BOBCAT T650...
