Cleaning Fuel Tank
/ Cleaning Fuel Tank #1
ryanbr
Bronze Member
White 2-105, Cockshutt 770
Have a 4 year old Honda 5.5hp engine that was sitting for 2 years with dyed gas in the tank. Anyway I have taken the tank off, cleaned all hoses and fittings etc. Emptied the old gas, rinsed with new gas, but it still is covered in rust on the inside of the tank. Any suggestions on how to clean this so I dont end up with another plugged filter? I was thinking my 3000psi pressure washer, but then I couldnt get every area of the tank....
/ Cleaning Fuel Tank #2
I take a hand full of bolts and nuts put into the removed tank and shake it around for a while then dump out and with solvent flush out the dirt and remaining stuff. usually works. some times a second time around for the extra hard things to break loose.
Water pressure doesn't get to areas needed.
ken
ken
Thanks, I contemplated that but then thought i may create a spark and vapors would blow my hands off. I will try it, hopefully I can still type to tell you it worked!
/ Cleaning Fuel Tank #5
Wouldn't blasting sand leave a bit of dust and residue that could clog the filter still? If you used the bolts/washers trick or even crushed gravel put some water or kerosene in there if you are worried about sparks. The chances of that are pretty slim I think. After you dump out the tank air dry it in the sun or over a heat vent. Then swish around some fuel and discard that. If the rust hasn't come out after all of that then you would be ok as long as you have your fuel filter in there.
/ Cleaning Fuel Tank #7
I usually buy a bag of aquarium gravel, then use some sand for a final finish, unless the tank has a sleeve or tube in the filler opening so it cant be overfilled, and for that I once tried sugar. What part of the sugar you can't shake out, you just melt/dilute out with hot water. Once the coating in the tank is compromised, it will always rust again, so I add just a touch of synthetic 2 stroke oil to the fuel for the remainder of the engines life and/or my ownership duration. This is for small tanks; usually motorcycle size.
/ Cleaning Fuel Tank #8
Factoring in your time to remove the tank rust; would it be more cost effective to buy a new tank?[/QUOTE
Small engine/lawn mower etc buy a new tank, tractor or similar could go either way, most motorcycle tanks seem to cost about the same as a new Ferrari engine, so one must make do..............
/ Cleaning Fuel Tank #9
Coud be from a number of places they replaced the timing cover seal and gaskets Head and valve cover gaskets. If you find oil in the egine bay but not on the ground , it could be oil that leaked out when they pulled the parts or was leaking before. Take it back and let them find out what it is
/ Cleaning Fuel Tank #10
As LRH says, once the interior rust has started it'll always return, and even though you've got a good inline filter, you're still in for carb troubles down the road.
There's a product for motorcycle tanks, been around a while : "Kreme."
It's a 3-step system for coating the inside of the tank. 1) Using a cleaner/solvent supplied with the kit--as Ken said, rinse/shake with nuts, bolts, ball bearings or whatever to loosen rust; wash w/ soapy water & rinse. (In a particularly bad tank, I had to do this twice.) 2. Kit-supplied acid-based etcher, to scarify the inside- wash w/soapy water & rinse after "etching." 3) An epoxy-based (I think) coating: after tank is completely dry and openings are sealed, pur in Kreme and rotate tank to coat all interior surfaces. Allow time (24hrs?) to dry, then use.
Did this to a particularly troublesome '76 XL250 and haven't had any rust issues in the tank for the past 8 years.... I think I'm remembering the process, but I could be forgetting something.... fortunately, my other bikes have all turned out to have rust-free tanks! :D
/ Cleaning Fuel Tank #11
A good parts store usually carries a kit to clean, strip and seal gas tanks. It is a time consuming process. I have taken small tanks to a radiator shop to be cleaned and resealed. That seemed pretty expensive also. I tried what you suggested with a gas tank on a two ton truck by pressure washing it clean. It didn't last with the gas sloshing around and the tank rusting even adding an extra gas filter couldn't stop trash getting to the carb.
/ Cleaning Fuel Tank #12
Guess I misspelled that-- it's "Kreem." There's apparently another product by KBS Coatings that works as well. Hope this helps--
/ Cleaning Fuel Tank #13
Hi everyone, new here, first post.....
I've cleaned quite a few motorcycle tanks with BB's and diesel fuel, shake it and let it soak.....do this several times and see where your at.
Thanks everyone. I used various nuts and bolts, and shook the **** outta the tank. Seemed to get most the crap out of it. I cleaned the carb, changed the filter, but now cant get spark. Checked the plug it seems fine in another engine. Always something.
/ Cleaning Fuel Tank #15
Welcome Crash&burn! As far as no spark cycle that on and off switch several times to see if that cleans the contacts. Or see if the wire has popped off of the switch. Those Honda motors are usually more reliable than most other small engines.
/ Cleaning Fuel Tank #16
Check the low oil sensor, I have had the same problem with a Honda 5.5 and right now I can't seem to remember if it was actually low oil or if it was just a loose wire on the sensor but either way, check it out.
Also, if you cant get the tank back into the condition you want, check ebay, I frequently see the Chinese Honda clone engine tanks for sale there and they usually go for $10-$15.00, they are interchangeable.
Checked the switch, seems fine. Cant find low oil shut off switch (maybe internal?). going to pull off the cover and have a look at the condition of the coil tonight.
I pulled the coil off and cleaned up the magnets. Also tried to clean flywheel as best I could, managed to get the starting magnet of the flywheel quite clean using a wire brush. -> Still no spark
Anyone know the air gap between the coil and the flywheel? Or is the air gap suppose to be between the coil magnets and magnet on the flywheel?
2014 Chevrolet Caprice Sedan (A61569)
2014 Chevrolet...
2014 Dodge Grand Caravan Van (A61569)
2014 Dodge Grand...
2018 Roadtec RP190E Highway Class Wheel Asphalt Paver (A61567)
2018 Roadtec...
2006 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A62129)
2006 CATERPILLAR...
TEST YOUR BID BUTTON! (A62129)
TEST YOUR BID...
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59905)
1999 TRANSCRAFT...
