Oil & Fuel Cleaning fuel tank on Kubota L345
   / Cleaning fuel tank on Kubota L345 #1
carlubu1
Yazoo City, MS
Kubota L345
Is there any way to flush or remove crud from fuel tank without completely removing the tank?
   / Cleaning fuel tank on Kubota L345 #2
You will need several old Cotton tee shirts,shop towels or old cotton rags that will fit in the filler hole. Drop a few of the rags in the tank take a broom handle or wooden stick and move the rags around to soak the crud. Take a coat hanger/wire and form a hook to remove the soaked rags. Repeat with more clean rags as needed. Be careful take your time,watch what you are doing so you don't damage your float assembly.
Thanks, stingray. I have actually tried this method but wondered if there were some type of liquid solvent that would be safe to use. I guess I will gather up some more old tee shirts.
   / Cleaning fuel tank on Kubota L345 #4
YoUr welcome,carlubu1 this method always works for me.
20ft Shipping Container (A48837)
20ft Shipping...
2012 FORD F-350 DUALLY (INOPERABLE) (A48992)
2012 FORD F-350...
4 IN WATER SPRINKLER (A48992)
4 IN WATER...
2014 Dodge Charger Sedan (A48082)
2014 Dodge Charger...
2006 Ford Explorer 4x4 SUV (A46684)
2006 Ford Explorer...
More info coming soon! (A48081)
More info coming...
