Cleaning engine
   / Cleaning engine #1
drjay9051
Morriston, Fl. 40 miles west of Ocala. More cows
Kioti DK 40 HST
OK. My fuel bowl cracked and engine is a mess. Anybody use one of those engine cleaners found in auto parts store? Stuff like gunk.
Is it safe? Do i need to wrap all electrical connections in saran wrap.?
   / Cleaning engine #2
I have always used products like Simple Green and some of the concentrated (mix w/ water) cleaners and had very good success with them. If you have a power washer, I don't recommend using it at full power....just be careful with it as you could take the paint off potentially. Good luck!
   / Cleaning engine #3
Use Gunk all the time...
Works better with warm engine and soak time.
Keeping water away from electrical components is always a good idea... especially the ignition system if so equipped...
After power washing on low setting, run the engine till dry and leave out in the sun all day...
Year ago, I would wash a couple of engines a day...
If the area is small... simple green with a brush and garden hose would work too.
Also... avoid cold water on a hot engine... exhaust manifolds don't take well to thermal shock.
   / Cleaning engine #4
I've always used automobile wheel cleaner. Spray it on, let it sit and wash it off. Cleans as well as anything else I have tried.
   / Cleaning engine #5
I tried Simple Green and much prefer it to anything else I have ever used. Try some.
   / Cleaning engine #6
I've also used Simple Green. Did a 50-50 mix with water and used it in a spray bottle to hit everything. Waited about 10 minutes and then used hot water from a garden hose to rinse and finish the cleaning. It worked well for me.
   / Cleaning engine #7
I would also suggest simple green or "purple power" .... one of the biodegradeable cleaners... Last time I used a can of GUNk, it was basically solvent in a can... (petroleum based)... If you are trying to wash off diesel, gunk is a similar petroleum... so Im not really sure how much it will really help..
As others have said, don't wash a hot engine, it tends to cause water to wick into connectors and is hard on hot metals.. Once you get it washed and rinsed, run the engine to full operating temperature to thoroughly dry the engine...
   / Cleaning engine #8
Gunk sometimes leaves whitish dried streaks. It also seems to "scald" the paint. Simple Green looks better than Gunk after I wash my motor with it. Keeps the shine and wet look in it.
   / Cleaning engine #9
Another vote for Simple Green, fantastic stuff. For de-greasing I use it straight and spray it on a cold engine with a squirt bottle. Wait 5 min and rinse. I use it diluted for washing the trucks and motorcycles, but remember it can etch aluminium, so don't let it sit for long and rinse well when using it on a bike.
   / Cleaning engine #10
Go to the por-15 website and order their marine clean. Excellent degreaser for most things when mixed to the directions. Removes all grease and oil. if there is bare metal it will rust almost immediately.
2007 Hino 268 Truck, VIN # 5PVNE8JVX72S50442 (A51572)
2007 Hino 268...
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
2006 UTILITY VS2RA 53 FT REEFER TRAILER (A52577)
2006 UTILITY VS2RA...
New Holland Boomer 55 Tractor (A52384)
New Holland Boomer...
Peterbilt 377 Semi-Truck (A52748)
Peterbilt 377...
