I second the crap gas. Thank the tree huggers and Obama for your gummed up carb.
Obama don't care, he don't drive, he has a chauffer.....
He's a first class CS'er IMO.
What I did this year, because all my carbs were gunked and gummed up real bad (despite using Stabil I might add) was I went to the auto parts store and bought a 1 gallon can of Berryman Carb Soak. It's some kind of enzyme or animine based solvent (wear rubber gloves) and it positively cleans the carbs (but you have to take the carb off and apart) to soak it in the supplied parts basket. You rinse the carb with water afterward and I blew mine out with an air hose. It takes all the gum and gunk out, as in clean as a whistle. The aluminum even shines like new,
I had a bunch of different carbs so I just wrote down the settings prior to taking them apart and all went back together just fine. 2 motorcycles with Kehin CV carbs,a rototiller with a side draft, my 4 wheeler with a Mikuni and my chainsaw with a Walbro.
I had the same issue.... only run with the choke on..... Thats because the idle jets and emulshion tubes are gummed up. My carbs looked like they had snot inside. Nasty stuff but the Berryman solvent did the job. Does it quick too. 15 minutes and rinse.
This fall, instead of Stabil, I'm going to run them dry.
