Sprayer Clean-up of sprayer
   / Clean-up of sprayer #1
stump54
Bladen County North Carolina
MF-2607H, MF-1540, MF-GC1710, Ferguson TO20
I just finished my first time spraying 2-4D on my hay field. As I don't think I'll be using it again until next year what is the best way to clean it, and prepare it for storage? It is a 55 gal plastic tank with a PTO pump.
I have three different sets of instructions from the sprayer, pump, and the weed killer; all are vague and different...
Thanks,
Gary
   / Clean-up of sprayer #2
I have a 15 gal on my ATV that I use to spray Roundup, weed killer, and insecticides. I just flush it several times with clean water. After the last flush, I put in a little water run clean water thru the pump and spray heads until empty. Of course, mine I can put in a couple gallons of water and pick it up and slosh the water around in it to clean the inside. They do make agents specifically to clean them, but I have never used them.
   / Clean-up of sprayer #3
A good, thorough flushing with water should get it clean, but then you'll probably need to put either oil or antifreeze in the pump to prevent corrosion while it's stored.
   / Clean-up of sprayer #4
What about using some Nutrisol mix on last rinse. The local Tractor Parts-Western Wear Store had some. I dunno exactly what all it does for the system. The store clerk said to use it. bjr
   / Clean-up of sprayer #5
TSC or any good farm supply store will have Nutrisol (or competing brands) 2,4-D isn't quite as bad, but glyphosate will "bond" with plastic, making it difficult to merely flush away with water.
I also like to fill the pump with diesel fuel to prevent corrosion. (Again, glyphosate (round-up) is the more harmfull, being "salt-based")
2006 Toyota Tundra 4X4 Pickup Truck (A50323)
2006 Toyota Tundra...
3pt Blower w/ 60 Gal Tank (A50120)
3pt Blower w/ 60...
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
2011 KOMATSU PC160LC-8 (A52472)
2011 KOMATSU...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
2009 MINI Cooper Coupe (A50324)
2009 MINI Cooper...
