California
Super Star Member
- Joined
- Jan 22, 2004
- Messages
- 15,029
- Location
- An hour north of San Francisco
- Tractor
- Yanmar YM240 Yanmar YM186D
After a year running near 100% biodiesel I think I have carboned up the injectors. Cranking speed is ok (and I've cleaned all the battery cables etc) but the first start of the morning just pushes raw fuel vapor out the exhaust, running (barely) on both cylinders, but not strong enough to exceed the starter's speed. I thought it was a cold weather issue and used the thermostart, and even a hair dryer, to give it warm air and get it running, but the problem remains now the weather is warm.
The local diesel shop said he sees a lot of crudded up injectors due to biodiesel. It seems to correspond to biodiesel ageing faster than petro diesel. He said he now asks about the fuel and when it was biodiesel, especially in an engine that gets intermittent use, he finds that he has to soak injectors in carb cleaner for a long time to free them up before working on them.
What is the normal useful life of injectors before they need cleaning? I know nothing has been done on this engine in the 6+ years I've owned it and I think it was parked for years in the second decade of its life. The Operation manual just says 'see your dealer'. What does the dealer do? Is it possible to disassemble and clean injectors myself?
I wonder if it would be better to simply put in new injectors, compared to rebuilding units that have probably been in use 30 years, since new isn't much more expensive than professionally rebuilt.
Has anyone had to do this?
