Dougster
Veteran Member
As I wait for the swamp to dry out enough in my back yard to support my tractor without getting it stuck... and for that nasty alligator to crawl back home to Florida... I am contemplating again exactly how I will eliminate the swamp once and for all time this summer now that I own a tractor w/FEL+BH. The problem is simple: Clay, clay and more clay. Nasty gray stuff that lives there starting no more than 2 or three inches below the surface all around my house and goes all the way down to that place where Satan lives!
To make matters worse, my "back forty" slopes down to the back of the house (i.e., the swamp area) and contains a bunch of natural springs. In other words, there are BOTH tons of gray clay right below the surface and a source of water to keep it wet and soggy much of the year. Regrading and terracing will help keep the natural springs under control where a previously installed drainage system failed... but what to do about all that clay?
In the past, there have been two schools of thought:
1) Dig it ALL out, throw down a layer of crushed stone at least 6" thick for better drainage... and then place an entirely new lawn atop that... OR
2) Do something... anything... in situ to the clay soil to make it less offensive.
Since the logistics and costs on preferred option (1) seem almost impossible, I would like your opinions on fallback option (2)
As background to where I am coming from... different folks at different times with absolute zero to tons of dirt experience (as in degreed, registered civil engineers) have talked about adding one or more of the following "ingredients" essentially through some combination of digging, regrading, mixing, tilling, etc.
1) Coarse Sand
2) Crushed stone
3) Mulch, peat, compost or wood chips
4) Limestone
5) Loam
6) Anything that is NOT gray slimy clay
Sadly, being laid-off now, my access to these civil engineering professionals is not what it used to be. Besides, I value the opinions of folks here even higher.
Anyway... do any of these ingredients, alone or in combination, make any sense to you? Will they do the trick? Other than total removal, how have you folks out there come to terms with slimy gray clay???
Dougster
1) Coarse Sand
2) Crushed stone
4) Limestone
5) Loam
Dougster
