Clanking and banging in 4wd
   / Clanking and banging in 4wd #1
1234567A
missoula,montana
kubota b7100
Hello- We have owned our Kubota for about 4 months now, and up until this early start to landscaping season have only used it to move some snow. It is a B7100 from the mid-1980's and has pretty high hours. Today we had been using it a good portion of the day with a harrow and on a break we had it sitting, idling, for just a few minutes. When we went to put it back into gear to work again (it was in 4wd and had been all day), it made a horrible clanking and banging noise. We quickly put it into 2wd and it seemed to run normally. Any attempts at putting it into 4wd resulted in the same clanking and banging noises. Any advice as to what could be going on and what we could expect to get this repaired? We bought an older model because it's all we could afford, and unfortunately we have just moved onto 3 acres of untouched land. That's a lot of landscaping *sigh*
   / Clanking and banging in 4wd #2
Crawl underneath while the tractor is off (not running) and check the drive shaft. It is long and pipe like. Try to move it around or side to side. It should not move. Good luck
2015 KENWORTH T370 QUINT AXLE DUMP TRUCK (A52576)
2015 KENWORTH T370...
2007 Ford Crown Victoria Passenger Car, VIN # 2FAFP71W97X154872 (A51572)
2007 Ford Crown...
24in Tractor Backhoe Bucket BT4555 (A53472)
24in Tractor...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
JOHN DEERE 5075GN LOT NUMBER 127 (A53084)
JOHN DEERE 5075GN...
TOW BEHIND FINISH MOWER (A50324)
TOW BEHIND FINISH...
