startagain
Has anyone else had a problem with a Kioti CK 3710 and the forward / reverse pedals. I have a problem in that the pedals stick down and therefore continue to operate after pressure is released. I notice it particularly reversing into my shed where the only way to stop the tractor motion is to press the opposite pedal. I have tried looking at the adjustment but nothing seems to be wrong, and after pushing the forward/reverse pedal several times it works perfectly. I have obviously tried lubrication but the problem persists. I thought initially that if I increased the pressure on the associated spring that would fix the problem, but I am perplexed with the issue continually correcting itself. If anyone has had such a problem, or can suggest anything that I might be able to do to fix this troubling issue I would be most grateful.
