CK35H w no rear hydraulics and Befco single line sickel bar
   / CK35H w no rear hydraulics and Befco single line sickel bar #1
kbest
Kioti CK35H
Can I use the boom or bucket joystick valve to use for the single line cylinder on the befco ( enrossi) sickel bar, the local dealer says only the rear double acting lever and connections can be used, plus they were clueless on the singleline, saying the cylinder needs two. any help here? apparently i need a single acting remote, but need more info here
   / CK35H w no rear hydraulics and Befco single line sickel bar #2
Yes, you can use the loader boom controls. You (should) disconnect both of the boom hoses.
I would use the downside coupler to connect to. You then would use the down joystick movement to raise the unit. You would use the float feature to lower the single-acting cylinder that is on your sickle bar.
By connecting in this way, you are able to operate the sickle bar hydraulic without ever putting pressure on the unused boom upside coupler.
Good luck.
thanks, thats what i was thinking, anyone know the thread on the kioti control block at the mid frame?
   / CK35H w no rear hydraulics and Befco single line sickel bar #4
Why, just use a quick coupler to match what you have and plug it into the existing loader couplers.
I dont have a front end loader- bucket. The ports are plugged on the control valve.
   / CK35H w no rear hydraulics and Befco single line sickel bar #6
Do you have the joystick to control that valve? I asking because some times they put an hydraulic block under the floor board with Pressure, Power Beyond and Tank that would be used to feed the loader valve. If this is the case, your situation will be a bit more complex.
yes i have the joy stick for the boom - bucket cylinders and valve, I just need to connect to the Boom down port, ie. thread type, size. the tractor is 90 miles away from me and i' m trying to get this stuff for when I go back up there.
   / CK35H w no rear hydraulics and Befco single line sickel bar #8
Unfortunately, it looks like none of these parts are listed out as far as what size anything is besides that everything is NA.
Post in the Kioti section and hope that someone with this or similar model can check on their tractor and let you know.
Otherwise, it looks like another trip for you. :(
2019 BOBCAT T770 SKID STEER (A51242)
2019 BOBCAT T770...
2015 Chevrolet Silverado 1500 Extended Cab Pickup Truck (A50323)
2015 Chevrolet...
Best 30' Grain Drill (A50514)
Best 30' Grain...
2025 84in Dual Cylinder Grapple Bucket Skid Steer Attachment (A51691)
2025 84in Dual...
Volvo DD24 Roller (A47384)
Volvo DD24 Roller...
