CK3510HST Question
   / CK3510HST Question #1
450
New Member
Fairbanks, Alaska
Branson 3725CH
Can the CK3510HST be plugged into a standard OBD2 code reader to read fault codes? Has anyone had any problems with the DPF system/Regin? Thanks in advance.
   / CK3510HST Question #2
Yes, the standard obd 2 16 pin connector is located on the right side of the engine compartment in front of the main fuse block. You can access codes, data etc. with a traditional scan tool set to read generic obd info.
Fuelhog2000,
Thanks for the info and that would help me since the closest dealership is 350 miles away.
   / CK3510HST Question #4
Wow, thats quite a ways away. Good luck. I just purchased a CK3510H myself a month ago and love it.
   / CK3510HST Question #5
I have the backhoe on my 3510 as well. Another piece of info that may help you is the male hydraulic connections that go into the rear remotes. Dealer told me they were proprietary and are $45 each. Hogwash, they are traditional 1/2 ISO Pioneer fittings that can be found at any tractor supply. I had to get some for a top and tilt kit I put on.
Thanks for the info and I will keep that in mind.
It will be later on this year(after wife's car is paid off) but I'm most positive it will be a Kioti. Probably the CK3510HST or maybe CK4010HST with loader, backhoe and rear offset grader blade. Just depends on price difference in the tractors.
   / CK3510HST Question #9
kioti has free loader offer or 0 finance right now check out kioti website
2025 25ft 1 Gauge 800 Amp Booster Cables (A50323)
2025 25ft 1 Gauge...
Same Row Crop 85 (A50121)
Same Row Crop 85...
2011 Hyundai Sonata Sedan (A50324)
2011 Hyundai...
2019 Ford F-150 XL (A50120)
2019 Ford F-150 XL...
2007 BobCat S175 Skid Steer (A52384)
2007 BobCat S175...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A52748)
2023 NEW HOLLAND...
