Ck3510 owner seat question
   / Ck3510 owner seat question #1
southernAL
Dothan, AL
Kioti CK2510hst
I don't own a ck3510 but just out of curiosity, what all can you adjust on the seat? Can you adjust the back forward or back? I tried to find pics or videos on YouTube but no one has any good details. Thanks
   / Ck3510 owner seat question #2
I don't have a ck3510, but I would guess the seat is the same as my ck35. The entire seat slides forward and back, the height can be adjusted, and the dampener can be adjusted to accommodate the weight of the operator.
   / Ck3510 owner seat question #3
I sat and drove the ck3510 a few months ago when test driving it. I don't recall a back adjustment. Amvcane's post is what I recall. They do offer one right side arm rest for it was an option though.
   / Ck3510 owner seat question #4
My CK27 has am adjustment for the back as well as forward back and the damper.
Thank you for the replies. Reason I ask, i've been doing some thinking lately about stepping up to a ck3510 from my ck2510. The seat is nice, I just wish it had an adjustment for the back because it leans back a little too much for my liking. I sat on a grand L Kubota a couple weeks and that was one feature it had that I thought was nice.
   / Ck3510 owner seat question #6
When I was young and dumb I put a racing seat in my jeep. It had zero adjustments. I shimmed the thing with a few tender washers to tilt it to the "perfect" angle. The washers went between the floor and the seat bracket. The seat bracket has 4 studs that mount it.
   / Ck3510 owner seat question #7
I had the same back tilt problem on my Bobcat CT235, I picked up a adjustable back lumbar cushion (you can add or remove foam) and added it on - solved the problem. Problem now Is I need to replace the seat, and cant find any aftermarket one that fit the safety switch. Anyone know of any? I have the delux seat with the suspension and for aft and height adjustments, Seat is hinged by bolts on front edge
3pt Cultivator (A50121)
3pt Cultivator...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2017 FREIGHTLINER...
Orange Signal Trailer (A50121)
Orange Signal...
2003 GMC C7500 16ft Cab and Chassis Truck (A51692)
2003 GMC C7500...
2020 Kubota SVL75-2 (A50120)
2020 Kubota...
2003 GMC 3500 Ambulance (NOT RUNNING)(NO TITLE) (A50774)
2003 GMC 3500...
