Hello,
I have been having some trouble starting my 2012 CK35 over the past 18 months or so.
The ignition switch turns to ON correctly, heats the glowplugs, opens the fuel solenoid, etc... but when the key is turned to Start there is nothing.
Over the past 18 months I have replaced the ignition switch, various relays, and occasionally had to jiggle a safety switch. All of these solutions are temporary, as eventually the same problem returns.
The battery, cables, ground and starter motor/solenoid are all good, so I am placing the blame on the endless safety interlocks that modern tractors seem burdened with.
When I connect the Big and Small terminals on the starter solenoid with a screwdriver the tractor starts up perfectly, so I have a cunning plan.
What are the negatives to connecting one wire to the battery positive and another to the Small terminal on the starter solenoid and linking them with a momentary switch (or push button) on the dash? This should allow me to bypass all the safety switches.
I understand the obvious negatives such as accidentally starting the tractor in gear, or with the PTO running, but having owned a Fiat tractor from 1978 to 2012 (with no such safety switches) that is not a problem for me.
I would appreciate anyone's thoughts on the matter.
Cheers.
Cheers.
