CK30HST Starting dash lights flicker
   / CK30HST Starting dash lights flicker #1
Notlaker
Bronze Member
Niagara-on-the-Lake, Ontario
Kioti CK30HST
Hi All,
Every time it is cold outside I have the same issue with starting. I have had the switch replaced already. When I turn the key on, all the panel lights go on and off and a clicking sound occurs (relay?). After a few seconds of this it stops and the glow plug light stays lit and I can start.
My Ck30 is a 2012 purchased in May 2012.
Any ideas and comments would be appreciated.
   / CK30HST Starting dash lights flicker #2
Sounds like a bad connection problem somewhere, if battery is full and charged ok. Take off cables and clean battery contacts is the first thing, then check battery ground strap connection and so on.
Mike
You would think a bad battery connection would affect only high current demand like cranking. However, once it stops flickering it cranks no problem. Also, if I stop and restart there is no issue. Only happens when sitting for awhile and cold outside (below 40F).
   / CK30HST Starting dash lights flicker #4
No, you should check and clean your cables.
I had checked when I first had this problem. Will go over everything again. Intermittent problems are such a pita!
   / CK30HST Starting dash lights flicker #6
Is the battery fully charged?
Yes it is. I just have to wait with the key on and the flickering and clicking stops after a few seconds and then everything is normal. Cranking is then strong and fast.
   / CK30HST Starting dash lights flicker #8
Check grounds.
   / CK30HST Starting dash lights flicker #9
Check ground starting at frame and negative battery cable. Wiggle the cable and see if there is any symptom difference noted. Make sure the battery clamp connections cannot move by grabbing the cable and trying to move the connection on the batteries post.
Check all connections at the firewall too make sure none are loose, and all the relay plugs are pushed into the relays completely.
Is it stored outside? Do you have the ignition switch cover that helps keep rain/water/moisture out of the ig switch?
Assume nothing- check everything. How long has this problem existed? How long ago did you replace the switch?
   / CK30HST Starting dash lights flicker #10
I have the exact same issue each year. I have to take the negative battery cable off, clean the contacts and put it back on with some of that electro-whatsits-called grease stuff and the problem goes away. Happens every single year once it gets cold. There must be deposits building up on the battery terminal or inside the negative cable.
I think I will replace the negative cable once it warms up, I had a positive cable on my old Allis Chalmers once that looked mint but NO current could get through it. Bizarre but it happens.
Good luck
2018 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
New Long Forks (A53002)
New Long Forks...
2012 JACK COUNTY 130BBL VACUUM TRAILER (A52472)
2012 JACK COUNTY...
2005 Mack CV713 Granite Truck, VIN # 1M2AG11C55M020965 (A51572)
2005 Mack CV713...
2015 FORD F-250 SUPER DUTY (A52472)
2015 FORD F-250...
2016 FREIGHTLINER CASCADIA DAY CAB (A52576)
2016 FREIGHTLINER...
