CK30HST Gear Selection--Use Brake
   / CK30HST Gear Selection--Use Brake #1
mrutkaus
Platinum Member
15 mi. N. of Winchester VA
Kioti CK30HST, Kubota BX-1500,
Well after three years I have suddenly discovered that if you press down hard on the brake when selecting a gear on the HST, it eliminates much of the sticking of the lever!
This is in addition if you wish, to pushing in the clutch.
Mike
   / CK30HST Gear Selection--Use Brake #2
That's weird. I just double-clutch . . . will try the brake stomp too next time.
Is this an early April Fool's joke? :)
no, no joke
seems to make it easier, almost normal at times (!) for me
mike
   / CK30HST Gear Selection--Use Brake #4
I have always found that holding the brake before switching from Low to High or vice versa makes a huge difference. I use the clutch too as well. If you think about it, there are two gears making contact and when you got to switch the gears, they are holding the weight of the rolling tractor on them. By pressing the brake, the weight is now on the brakes and the gears are more free to move and switch.
   / CK30HST Gear Selection--Use Brake #5
I'll remember the brake stomp if it happens.
Stomp the break and treat it as a normal transmission with no problems!
Mike
   / CK30HST Gear Selection--Use Brake #7
Okay!
I treat it as a normal transmission without the brake stomp!
I hope it continues working smoothly!
Rex
   / CK30HST Gear Selection--Use Brake #9
LOL! A chuckle to get my morning started right!
Just one of the 'things' I love this l'il tractor for is it's GO power. 4WD Low, rear axle locked, it plows the dirt and knocks small trees out of the way about as well as being on tracks. I coulda' started using this CK30 years earlier rather than keep using the l'il JD dozer for everything, which tears up the ground and driveway on the way to and from jobs (of course.) Was pleasantly surprised that a HST could handle it, and I Love my CUT.
   / CK30HST Gear Selection--Use Brake #10
WOW! I will have to try the brake thing.
2012 Cadillac CTS Sedan (A50324)
2012 Cadillac CTS...
City of Lakeland (A51691)
City of Lakeland...
43013 (A51691)
43013 (A51691)
Case 586H (A50120)
Case 586H (A50120)
2017 Ford F-550 Ext. Cab Valve Maintenance Vacuum Service Truck (A50323)
2017 Ford F-550...
1998 East Frameless Dump Trailer (A50774)
1998 East...
