CK30HST bad ignition switch
/ CK30HST bad ignition switch #21
The quality of my rear remote plugs is way way better than those at the loader hookup. The ones at the loader were bad (dry rotted) from the very start. This is a poor reflection on Kioti. Why skimp on something so visible and inexpensive? It is the only part on the tractor that I have found to be of consciously selected inferior materials. They look like (and probably are) cheap chinese imports. Mine lasted about 1 minute in the brush. They shouldn't even waste the time to put them on. Just Horrible! I'm thinking of removing them entirely because they are an embarressment to me and my machine.
As for the rear remote covers that Rick Wallace installed, they look like they will last for many many years - heavy duty and of different, black material (less susceptible to UV deterioration).
I'm being careful with the key cover. While it's of fair material, better than the loader's, it won't last forever. Eventually it's gonna become brittle and split,. This too could be of better material (like my rear remotes). But, at least it is acceptable, unlike the loader plugs.
Does everyone know why tires are black when rubber is naturally light? Carbon is added to absorb sunlight so the rubber does not. One would think the materials guys would practice this with all such polymer products subjected to a lot of UV exposure. I guess carbon cost more. Incidentally, my remote covers on my JD are black, 13 years old, and show no signs of deterioration.
/ CK30HST bad ignition switch #22
/ CK30HST bad ignition switch #23
Highbeam,
Try graphite the next time you want to lube your key switch. But, don't use too much.
/ CK30HST bad ignition switch #24
Highbeam,
/ CK30HST bad ignition switch #25
I'm not squirting anything in that keyhole unless it fails on me. I thought I ruined something big when my tach just died like that. Maybe a little lube on the key itself would properly lube the tubmlers without affecting the contacts. Maybe some dielectric grease.
/ CK30HST bad ignition switch #26
/ CK30HST bad ignition switch #27
Dielectric grease works good if you can get it in where it is needed. Powder graphite is the best thing for just about any lock.
/ CK30HST bad ignition switch #28
</font><font color="blue" class="small">( I'm not squirting anything in that keyhole unless it fails on me. )</font>
Whats surprising is I didn't lube it or even sneeze at it.
RAVE: Jon DePratt of DePratt Equipment is sending me a warranty switch if i send the bum one back. I did not even buy the rig there being in WA state and not knowing of him then.
My local dealer may have come through eventually but said they would "get back to me in a couple days" which I didn't find encouraging. Jon was right there- right now...HIGHLY RECOMMENDED for your parts/ tractor purchases!! /forums/images/graemlins/laugh.gif
/ CK30HST bad ignition switch #31
That's great. /forums/images/graemlins/grin.gif
I'll need to order a remote setup one day and I see no benefit to ordering one from my dealer, you can bet I'll order one from one of the online Kioti dealers.
/ CK30HST bad ignition switch #32
I got the switch from Jon--my local dealer "got back to me" 5-6 days after initial inquiry tell me they had the part too.
When someone says they will get back to you in some days instead of just handling the issue- one doesn't get the impression anything will be done.
The new switch comes with the mechanical part and the electric part assembled- if you want to keep your original keys you can unscew only the electric part and transfer it to your existing tumbler body.
The original keys have the black plastic w/ logo, replacement ones are just regular metal keys for those who care...
Now about time for the 50 hour HST oil change...FUN!!
I didn't look at the key cut so I can't say at the moment...
/ CK30HST bad ignition switch #36
All keys are the same..... the all metal keys are the old style... most of the switchs don't come with keys anymore..... that was just a bouns.... extra keys /forums/images/graemlins/grin.gif
I just a*s-umed they'd be different...
maybe because they bothered cutting teeth on them /forums/images/graemlins/grin.gif
and it looked sooo much like a car ignition switch...
jeesh isn't anything sacred anymore??
Thanks Jon and everyone can ignore my last ignorant post...
/forums/images/graemlins/grin.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/grin.gif
2011 PJ Trailer T/A Tilt Trailer (A61569)
2011 PJ Trailer...
2016 CATERPILLAR 416F2 BACKHOE (A63276)
2016 CATERPILLAR...
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A58375)
2007 FORD F750 XLT...
2461 (A58376)
2461 (A58376)
2024 John Deere 4066R Tractor (A63116)
2024 John Deere...
Forklift (A56857)
Forklift (A56857)
