3-Point Hitch CK30HST - 3PT Hitch NOT RAISING
   / CK30HST - 3PT Hitch NOT RAISING #1
djdowd
NW New Jersey
Kioti CK30HST, BX2230
I can't get the 3pt hitch to raise.
The tractor's been sitting in the barn for the past 5 months.
I've finally got some time to play.
The hitch was locked in the up position from last use.
Turning the (release) knob led to is going down on its own.
But I can't seem to get it to go back up.
I started the tractor and pulled back on the lever to raise it - nothing happens.
What am I doing wrong?
Does the fact that I've just re-connected the backhoe have anything to do with this?
   / CK30HST - 3PT Hitch NOT RAISING #3
It likely does. Why are you using the BH and the 3ph at the same time? The hydraulics are often set up in an either/or fashion.
   / CK30HST - 3PT Hitch NOT RAISING #4
If you don't have the rear remote, that infernal thumb valve by the right rear tire may be the problem. Reach up under there and give her a turn or two,or three.
Tom
   / CK30HST - 3PT Hitch NOT RAISING #5
On my CK30HST, I can't move the 3pt arms if the BH is active. I say active as I have the rear remotes and if I have the control valve in the center position, no flow to the BH, then the 3pt arms will move. If I have the 'remote' control in either the forward or rearward position... the 3pt arms will not move. HTH.
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
Wolverine Quick Attach Brush Grapple (A50515)
Wolverine Quick...
INSPECTION (A51573)
INSPECTION (A51573)
Great Plains Nutri-Pro NT-30 Nh3 Applicator (A50514)
Great Plains...
2001 MACK MR688S TANDEM AXLE ROLLOFF TRUCK (A52141)
2001 MACK MR688S...
Marliss Industries Grain and Soybean Drill - Selling ABSOLUTE NO RESERVE (A52748)
Marliss Industries...
