johnsopa
Hi folks. I have a frequent and recurring bogging problem that appears to be debris or water in the fuel tank. Lines have been bled, fuel filter changed, etc.
So, I'd like to take the fuel tank out to inspect inside to make sure there isn't some debris inside that's settling down and clogging the fuel line.
I have a Bobcat CT230 (same as Kioti CK30H) but can't figure out how to remove the fuel tank. I have Kioti service manual but the only place it talks about removing ("separating") the fuel tank is after the engine and clutch has been completely separated (i.e., the front half of the tractor is separated from the back half).
I'm hoping there's a better way but I can't figure it out.
Any suggestions or instructions would be appreciated.
Thanks!
Thanks!
