CK30, connector
   / CK30, connector #1
Steve_Miller
Veteran Member
Nova Scotia, Canada
2006 Kioti CK30HST
that is found just under the plastic shroud directly above the brake pedals. It has green wires and one is 12V. Does anyone know what it is for? I was wanting to use it for my diverter solenoid.
Steve
   / CK30, connector
No, it's just an empty connector hanging there.
Steve
   / CK30, connector #4
You could put a 12 volt test light on it to see if its a key on battery source or unswitched. You could pull fuses with test light on till bulb goes out to see what fuse its on.
2017 Bobcat E32i Mini Excavator (A50322)
2017 Bobcat E32i...
John Deere 7130 (A50120)
John Deere 7130...
2012 Ford F-250 Crew Cab Pickup Truck (A50323)
2012 Ford F-250...
Bad Boy 31HP Pro Series Mower (A50514)
Bad Boy 31HP Pro...
Ford 1710 Tractor (AS IS) (A50774)
Ford 1710 Tractor...
New Holland 477 Swather/Mower Conditioner (A52748)
New Holland 477...
