twigpig
When I bought my CK30 with about 350 hours on it the front axle was really low on gear oil. I didn't think much of it since any oil I saw I attributed to the leaking oil cooler. Today I somehow stripped the tie rod end nut off of the threaded bolt on part and the tie rod popped off. I am ordering replacement tie rod ends tomorrow. While I was down there I noticed that the front axle is leaking. It looks like it is most likely coming from where the left axle swivels for turning. The site glass is showing that the gear oil is low again. The tractor has about 390 hours on it now. Has anybody else had problems with this seal? How hard is it to pull the hub part off to change the seal? Would I need any special tools? I changed the front bearings on my Case 580C but that was not four wheal drive. I do not have a trailer. I also do not have a shop manual for this tractor. I was advised they are not much help. I will not take the tractor back to the dealer that the previous owner bought it from.
