CK30 are remotes open center?
   / CK30 are remotes open center? #1
Mark_G
Va
Kioti CK30 Synchro Shuttle
I have a pair of hydraulic lines for my rear implements (came with my tractor for the backhoe). I am now setting up a Tractor Supply woodsplitter and it can be set up for open or closed center hydraulics, and I am unsure what I have, and I don't have documentation for the remotes. The rear control has the detente so the lines can stay open (or it did to I removed the ball bearings and lost one while re-installing (anyone know the size and where to get a replacement set?)). Does anyone know what set up (open or closed) center I should use?
Thank you,
Mark
They looked a little distorted at the time. I think they are 11mm, but was wondering if anyone knew off hand.
Thanks,
   / CK30 are remotes open center? #4
As mentioned, the remotes are an open center valve. My valves still have the detents so I don't have a clue as to the ball size. I've never had a need to take them apart.
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A52748)
Kuhns AE10 Small...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
2012 Hyundai Genesis Sedan (A51694)
2012 Hyundai...
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A52748)
2020 New Holland...
2021 ALLMAND BROS, INC. NIGHT LITE TOWER (A52472)
2021 ALLMAND BROS...
