mrutkaus
Platinum Member
- Joined
- Feb 1, 2004
- Messages
- 990
- Location
- 15 mi. N. of Winchester VA
- Tractor
- Kioti CK30HST, Kubota BX-1500,
Someone recently suggested turning the air filter housing so the intake didn't come from right on top of the battery.
Just remove one of the housing strap bolts completely to rotate the housing.
Put it pointing front/downward at about 45 degrees; if you point it straight toward the front or up, the headlight connector will crack it when you close the hood!
Mike
Mike
