CK27HST wrong fuel filter???
   / CK27HST wrong fuel filter??? #1
Rebeldad1
Veteran Member
Hughett Bend Washington
Kioti Tractor, John Deere Mower,New Holland Mini Excavator
I have a 2010 CK27HST. I bought a wix 33507 paper filter for it.
Removed the old one and tried to push on the Wix but it wouldnt fit.
Did the "finger test of the filter holes and the Wix filter inside diameter was smaller then the factory one.
Went to the Wix site and looked up the diameter thinking it was mis boxed. Measures exact 0.795
Does anyone have a filter laying around that they could measure?
   / CK27HST wrong fuel filter??? #2
From my spares for a 2004 CK30hst, Kioti part #84612-43160. Inside diameter .787"-.789" depending on where you measure the diameter of the hole. Outside diameter 1.960". Length 3.495". Your 2010 CK27hst, from the manual, should use the same filter as mine. The Wix should fit by your measurement.
Hmmm.
I ordered a couple from the dealer today. along with a few more fun parts.
They say about 1 1/2 weeks or so. some are coming from the mother ship.
Will see then
   / CK27HST wrong fuel filter??? #4
I get my parts and filters from Nolts equipment.com Very good prices and quick delivery. I only use OEM filters....takes the guess work out.
   / CK27HST wrong fuel filter??? #5
You might also look at the filter base on the tractor, the previous owner of my CK20 left a metal filter end attached (see pictures below). I could not get a new filter to fit on, once this old part was pried off, a new filter fit without issue. I started a thread here about it a year or so ago.
Rancho...
Found the old thread, not sure this will work never done it before... http://www.tractorbynet.com/forums/kioti-owning-operating/298602-fuel-filter-ck20-adding-lubricant.html
McDon 75s 40' Flex Draper Head (A52349)
McDon 75s 40' Flex...
AGT Skidlaoder Post Hole Digger (A50774)
AGT Skidlaoder...
2020 John Deere 260E 26 Ton Articulating Off-Road T/A Dump Truck (A50322)
2020 John Deere...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
Massey Ferguson 383 (A50120)
Massey Ferguson...
2019 PETERBILT 567 TRI-AXLE MID-ROOF SLEEPER (A52472)
2019 PETERBILT 567...
