CK27 HST Fuel tank removal
   / CK27 HST Fuel tank removal #1
Charlie99
CK27 HST
Hello,
I just joined, and am hoping someone can help me with a fuel tank problem. My 2008 CK27 HST has developed a leak in the fuel tank. I am trying to remove it and just can't get it completely loose. It seems like the only thing holding it in now is at the bottom of the support frame. The parts diagram shows 2 bolts down there that come in from the back side, but I haven't been able to locate them from under the dash. Has anyone ever run into this? I'm totally befuddled! I hope someone can help.
Thanks,
Charlie
There seems to be an unbelievable amount of knowledgeable people on the forum, so I'm surprised that no one has commented. I'm really frustrated with this problem, and am about to take a hacksaw and pry bar to the frame around the tank. Any insight would be greatly appreciated!
   / CK27 HST Fuel tank removal #3
I would just keep unbolting brackets to remove the tank and not cut anything.
Thanks Peter for your advice. It motivated me to plug ahead. I removed one of the heavy support arms for the front end loader, and was able to pry the tank out of there. Found that the seam on one side of the tank was split open. Success! Thank you.
2005 Freightliner M2 106 Dumpster Carrier Truck (A51692)
2005 Freightliner...
2014 MACK GRANITE (A53843)
2014 MACK GRANITE...
2014 International DuraStar 4300 4x4 Terex BT3063 63FT 15 Ton Crane Truck (A51692)
2014 International...
2021 CHEVROLET SUBURBAN (A53843)
2021 CHEVROLET...
2007 INTERNATIONAL PAYSTAR 5600 Bucket Truck (A52384)
2007 INTERNATIONAL...
1992 Ford E350 Box Truck (A53117)
1992 Ford E350 Box...
