ck2620 - trans fill line
   / ck2620 - trans fill line #1
ck26
ck2620
Hi All,
New owner on a 2620. Should the transmission fluid be to the fill line or between the fill line and the start of the dipstick? I cannot tell from the manual as it only refers to the "upper limit".
I know it seems like a dumb question but there's no range on the stick. The coupler for the 3rd function was leaking and that's why I am trying to see if its low now
thanks
In case someone searches (like I did) before posting. I ended up going to the dealer and asking. They said fill to the line. Just above is ok. Not sure why the manual doesn't just call it the fill line instead of upper limit and pointing to the top most portion of the flat part. Makes it seem like you should fill past the line.
   / ck2620 - trans fill line #3
Few days late but I make sure its on the dipstick anywheres up to the lne. As long as you see fluid on the stick. That stick goes into a holding tank for the hydr fluid
thanks for replying. thats good to know
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A49461)
12-Wheel Pneumatic...
(2) Tractor Tires and Rims with Spacer (A50860)
(2) Tractor Tires...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
2011 Land Rover Range Rover Sport AWD SUV (A48082)
2011 Land Rover...
1986 CATERPILLAR D6H HI-TRACK CRAWLER DOZER (A51242)
1986 CATERPILLAR...
Craftsman LT2000 42in. Riding Mower (A49346)
Craftsman LT2000...
