Comparison CK2510 vs CK2610
   / CK2510 vs CK2610 #1
bier1064
Mead, WA
Kioti CK2610 HST
I am a first time tractor buyer and looking to buy in the next few weeks. I'm looking at either a CK2510 or CK2610 both in HST, my question is, which is better suited for my needs? I have only 3.5 acres but about 250-300 yards of gravel driveway that needs plowed and maintained. Also cutting down grass and weeds and cleaning up downed trees and limbs.
Thanks for any suggestions.
   / CK2510 vs CK2610 #2
Welcome to the Bynet.
I would strongly consider the CK2610 for its larger frame, more powerful engine and especially the 3 speed hst.
   / CK2510 vs CK2610 #3
For your needs, and the fact that the CK2510 now has a mid mount mower and the 2610 does not, I'd go with the 2510.
   / CK2510 vs CK2610 #4
As much as I love my 2610, I would say the 2510 would fit you better. But the most important part is to sit on them both and really think about your comfort! This was my deciding factor, I'm 6'3" and the 2510 was crapped and I couldn't see myself comfortable sitting for extended periods of time doing loader work or much of anything on the 2510.
It doesn't come standard but a mid mount PTA is available on the 2610.
Comfort comfort comfort!!!
   / CK2510 vs CK2610 #5
I agree. Comfort is really important. I went in looking to buy a CK 2510 but it was cramped and the rocker HST pedal for my large feet was a no go. Ended up getting a CK 3510 because it just fit better.
   / CK2510 vs CK2610
Thanks all for the advise. I agree comfort is important. I have tested the CK2510 and wasn't too impressed with the FWD/REV pedal, also felt a bit cramped. I'm going to the dealer and see if they have a CK2610/CK3510 that I can test.
   / CK2510 vs CK2610 #7
Wow, the 3510 is in a completely different class than the 2610. Bigger frame, more weight, bigger hydraulics, bigger tractor (35HP). Probably WAY overkill for you. Nice tractor, I have it's predecessor for my 25 acres. I do agree that if you don't like the 2510, you should look at the 2610. I also think the 2610 either has a MMM, or one is in the works. Also, there is the CS2410, which also has a MMM.
   / CK2510 vs CK2610 #8
2610 and 3510 have same frame and same size. Only difference is HP and FEL has higher lift capacity.
   / CK2510 vs CK2610
Thanks 12Bravo, I didn't think Kioti's website would be that incorrect.
   / CK2510 vs CK2610 #10
I'm going to assume you are being sarcastic.
If you think the website if off a bit, wait till you read the owners manual, good luck!
CATERPILLAR 740B OFF ROAD DUMP TRUCK (A51242)
CATERPILLAR 740B...
Komatsu D39PX-24 Crawler Tractor Dozer (A49346)
Komatsu D39PX-24...
2014 MACK GU813 GRANITE ROLL OFF TRUCK (A50854)
2014 MACK GU813...
2013 Ford F-150 (A50397)
2013 Ford F-150...
MT-500 Tack Trailer (A49461)
MT-500 Tack...
2014 MACK CXU613 (A50854)
2014 MACK CXU613...
