CK2510 lights that come on the the instrument panel
   / CK2510 lights that come on the the instrument panel #1
robbiele
Gate City, Virginia
John Deere 755
I just purchased a new CK2510 and I don't think the instrument panel lights are working correctly. What lights illuminate when you turn the key to the on position? The manual isn't clear per usual. Thanks.
   / CK2510 lights that come on the the instrument panel #2
Can't remember what all lights up, but they don't all light up.
   / CK2510 lights that come on the the instrument panel #3
all should light up as part of the 'bulb check' part of the starting procedure.
After a few seconds only batt and oil pressure will remain lit because it's not running - so no oil pressure or charging.
My 4WD light doesn't light when I'm in 4x4..probably a wire off the 'sensor', where ever it might be. When I get around to doing the LED lights on the ROPS and adding a power port on the rear I'll have a look at it.
Too busy using it now to bother.
Swict 84" Bucket (A50121)
Swict 84" Bucket...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
2016 Laymor SM300 Towable Ride-On Rotating Sweeper (A50322)
2016 Laymor SM300...
Case-IH 580 Super N (A50120)
Case-IH 580 Super...
2010 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2010 Ford F-150...
