CK2510 HST Questions
   / CK2510 HST Questions #1
KozMan73
Vancouver Island
None Yet
Just about to pull the trigger on a CK2510 HST TLB combo, but the fact that it only has a 2 speed HST is holding me back. Can any owners give there experiences with the performance of this tractor, going up hills, mowing, grading etc.
TIA
   / CK2510 HST Questions #2
I haven't used it. I have used the CK20, but it was a gear model, and I own a CK25 gear model. Also two range. While three would be better, I haven't long for anything else. Maybe the gear is different. I do loader work by switching from 1 low to 1 high and it works good for me. I push into the pile in 1 low, fill, back out, stop and switch to 1 high. This is more than fast enough for transport.
I would say if you are working on hills, and want to go fast, it might not be the tractor for you in HST. If you don't have a need to speed up hills, then it'll be just fine. Gear may perform better on steep slopes (wrt to travel speed).
2005 MACK GRANITE (A52472)
2005 MACK GRANITE...
2012 SULLIVAN PALATEK AIR COMPRESSOR (A52576)
2012 SULLIVAN...
1999 Toyota Camry XLE Sedan (A50324)
1999 Toyota Camry...
2007 Hyundai Sonata GLS Sedan (A51694)
2007 Hyundai...
2019 RBR Venturi 380 (A52748)
2019 RBR Venturi...
NEW Fork Extensions (A53002)
NEW Fork...
