Ck2510 fuel filter replacement
   / Ck2510 fuel filter replacement #1
southernAL
Dothan, AL
Kioti CK2510hst
Can someone with a ck2510 help me out and look in your manual on how to replace the fuel filter. Bleeding the system is where I am scratching my head. According to the manual there is a Open, close, and air bleeding section to the fuel dock valve. Down is open, right is close and left is air bleeding? My valve only has the position for the open and close. Has anyone replaced their filter and bled the system? I need some help. I'm wondering if this might be the cause of my tractor stalling out. Either way I'm going to call the dealer this week, just seeing what say you.
   / Ck2510 fuel filter replacement #2
When I changed mine I shut the fuel valve off, removed the bowl and old filter, cleaned the bowl, installed the new filter, filled the bowl with fuel before installing, then opened the fuel valve. Then I opened the bleed screw next to the fuel valve until fuel ran out, closed the screw, started the tractor and checked for leaks.
when you say bleed screw, is that one of the 10mm bolt head screws?
Think I figured it out. Thanks handtools!
2005 Jeep Wrangler 4x4 SUV (A50324)
2005 Jeep Wrangler...
2001 Ford F250 Pickup (RUNS) (TITLE) (A50774)
2001 Ford F250...
2014 Ram 1500 Crew Cab Pickup Truck (A50323)
2014 Ram 1500 Crew...
2009 Cat 140M VHP Motor Grader (RIDE AND DRIVE) (A50774)
2009 Cat 140M VHP...
New Holland 273 Square Baler (A50774)
New Holland 273...
1973 TANDEM AXLE DUMP TRUCK (A52576)
1973 TANDEM AXLE...
