CDBiker220
- Joined
- Jul 31, 2024
- Messages
- 1
- Tractor
- CK2510
So I forgot to connect my mid-mount mower deck PTO shaft. I backed up and it bent under the deck, tweaking one ear on the male splined shaft for the U-joint bearings (I think I can bend this back), but it broke the endcaps for the u-joint and I lost some needles. If I could source a new u-joint I think I could fix it. Just curious if anyone has any info. I can post pics at some point. Going to take measurements and start searching to see if it is a standard u-joint.
Update: Found the manual does have a u-joint listed and the shaft I bent, if I cant fix it (unfortunately u-joint/bearing is over $100 and shaft is over $300). U-joint appears to be about 2.320" across the end caps with a .970" end cap diameter.
www.michiganironandequip.com
Parts Finder Michigan Iron & Equipment Morrice, MI (855) 265-4590
