I was at a Kioti dealer today, they had a 2006 CK30 w/KL130 on it with a fix, ala KL120 fix. It was MUCH more stout than the KL120 fix, but basically the same design principle. Apparently it fits most, but not all, of the KL130's.IslandTractor said:If the loader is cracked you might bargain for a discount as you'd need to hassle with getting it fixed at some point. It doesn't affect your ability to use the loader but it will eventually (when Kioti FINALLY figures this thing out) require a fix that could involve a trip to the dealer (for the tractor).
IslandTractor said:Take off the six machine screws holding on the inspection plate over the torque tube (the piece that connects the left and right half of the loader). Check for hairline cracks starting either at the bolt holes themselves or, more typically for the KL130 loaders... at the origin of the gussets (welded inserts) at the edge of the inspection opening.
