ck25 hydraulic lag at startup?
   / ck25 hydraulic lag at startup? #1
cconklin
Hello all, I started noticing a hydraulic lag when I first start my tractor. I'll step on the foot pedal and it may take 2-3 seconds for the tractor to start to move. If I use the tractor everyday the lag is not present. The fluid level is good. I changed the fluid and filters about 10 hours ago. Any help or suggestion would be great. Note that once the initial lag is gone, the tractor runs fine and the hydraulics seem fine. Good power, no excessive noise etc. Thanks.
   / ck25 hydraulic lag at startup? #2
That's normal. My CK30 has always done that (for 4.5 yr now). Apparently
some of the oil drains back in the HST when the tractor rests for a while.
Clearly, it is a different design, vs. other HST units, as no JD of mine has
any detectable lag.
   / ck25 hydraulic lag at startup? #3
Yep, I agree. My CK25 has always done that. 4 years old now. I usually wait about 20 seconds before I creep, very slowly, out of the garage ( so I don't asphyxiate myself). If I go earlier, the lag is bigger. Even after 20 seconds, I sometimes feel a tiny lag.
2012 MAC MFG 53' WALKING FLOOR REFUSE TRAILER (A53426)
2012 MAC MFG 53'...
2014 KOMATSU PC490 LC-10 CRAWLER EXCAVATOR (A52576)
2014 KOMATSU PC490...
2019 PETERBILT 567 TRI-AXLE MID-ROOF SLEEPER (INOPERABLE) (A52472)
2019 PETERBILT 567...
1989 Ford FT900 T/A Cab and Chassis Truck (A51692)
1989 Ford FT900...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
2023 LMC M30018 LOT NUMBER 207 (A53084)
2023 LMC M30018...
