CK25 Head Gasket
   / CK25 Head Gasket #1
jthgn
Alexandria, KY
Kioti CK25
Hey guys, gonna start a head gasket repair on a CK25, 1000 hours. No oil or coolant mix, no white exhaust but radiator bubbling like a jacuzzi with exhaust gasses coming out. No bueno. Have the manual. Looks pretty straight forward but not finding the flywheel "peek" window for the timing marks. Has anyone done one of these. Would imagine CK27, CK30, CK35 probably the same?As always thanks in advance for your help!:)
   / CK25 Head Gasket #2
Make sure you have all the parts and torque specs before you start. Are the headbolds (torque to yield)?
Nothing worse than having to stop working and wait for something you over looked.
I have done a lot of truck engine head gaskets. As long as you have a good manual, and all the parts you need, it should be fairly easy. I presume you are experienced in this area.
   / CK25 Head Gasket
Yep, torque to yield bolts. Done quite a few car and truck head gaskets but never a diesel. Looks pretty straight forward but like I said I can't seem to locate this timing window on the flex plate/fly wheel. Anyone have experience with it?
   / CK25 Head Gasket #4
The site window to flywheel marks gets cover up by the loader mount frame. Have to remove the loader mounting frame to see it.
   / CK25 Head Gasket #5
Why do you need to get to the timing window?
Does the engine have over head camshafts?
I just presumed these little diesel engines were cam in block push rod.
   / CK25 Head Gasket
Hey all this post is a little old but the latest one I could find. I'm pretty sure the head gasket went this morning. Lots of sweet smelling white smoke and bubbles in the over flow . Sure I can tackle the fix , I dont have a repair manual though can anyone help me out?
Do you have DropBox? Can send instructions via DropBox, too big to send via email.
   / CK25 Head Gasket
no i dont sorry
Repair was pretty straight forward, I didn't need manual except for head bolt torque specs which is 80 ft lbs, valve cover bolts are 8 ft lbs. Need new bolts for heads as they are torque to yield. Got all parts from local Kioti dealership. Don't forget to remove negative battery terminal before you start work. Probably 2 hrs, take your time and have fun.
   / CK25 Head Gasket #9
do i need to remove the fuel tank ? the dealer said he would send the necessary pages from the service manual so that should help .
   / CK25 Head Gasket
yep. As you work your way to the head it'll be painfully obvious what needs to come off and what you can loosen and just move out of the way.
2012 SOUTHERN VAC  130 BBL STEEL VACUUM TANK TRAILER (A52472)
2012 SOUTHERN VAC...
GS-3246 MAN LIFT (A52472)
GS-3246 MAN LIFT...
2007 INTERNATIONAL 4300 ROUSTABOUT (A52472)
2007 INTERNATIONAL...
Killbros 260 Seed Conveyor (A52748)
Killbros 260 Seed...
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
