CK25 Brakes
   / CK25 Brakes #1
RADDAD50
Bronze Member
Sonoma County, Calif
CK25 Gear, year 2006
The brakes on my CK25 Gear are not releasing completely. I have checked the free play and all the external linkage and it is all correct? Is there anything else I should be looking for externally ?
   / CK25 Brakes
Brakes fixed, I found that something had hit the steel lever connected to the in board brake shaft. I removed the lever heated it and hammered it back straight. I hope this helps some else when they find there brakes not releasing completely.
LEGEND  2615 (15) BAT WING (A52472)
LEGEND 2615 (15)...
Grove 4x4 Rough Terrain Hydraulic Crane (A51691)
Grove 4x4 Rough...
MQ POWER 25KW GENERATOR (A52472)
MQ POWER 25KW...
MARTIN - SET OF 12 COULTER MOUNT MARTIN ROW CLEANERS (A52748)
MARTIN - SET OF 12...
EZ-GO Textron Electric Golf Cart (A51694)
EZ-GO Textron...
2016 Chrysler 200 Limited Sedan (A51694)
2016 Chrysler 200...
