CK20S no power steering, loader or backhoe but moves
   / CK20S no power steering, loader or backhoe but moves #1
Greg9504
Ottawa, Ontario, Canada
2004 JCB 212S
Hi,
Neighbours CK20S is having hydraulic issues. All at once the loader, backhoe and power steering stopped working. It is an HST transmission and it can move forward and reverse. Any ideas where to look?
At the time he was pulling up t posts with the loader, so it was probably under a good load.
Greg.
   / CK20S no power steering, loader or backhoe but moves #2
Use a 3000 psi hyd gage and check the relief pressure.
Check all the filters.
Check fluid level.
Check for pump flow.
FWIW there is no relief bypass noise when any of the valves are moved, fluid level shows full. Haven't checked pressure. Is there a test port ? What type of threads do the hydraulics use?
I assume the pump on the right side of the engine is the one that drives all the hydraulics?
Thanks.
Greg.
   / CK20S no power steering, loader or backhoe but moves #4
You can install a 3000 psi gage in a tee at the IN port of the loader valve and read the pressure for any attachment operation.
   / CK20S no power steering, loader or backhoe but moves #5
I just had similar issues with my CK 20. It turned out to be the HYD pump. It's in the shop now. Pump is around $500. With labor and I'm having liquid added to rear tires. The bill is expected to be $1200.
Kubota BX23 4x4 Backhoe (A51573)
Kubota BX23 4x4...
2000 Volvo VNL Truck, VIN # 4V4N21JF4YN250174 (A51572)
2000 Volvo VNL...
2017 Snapper Pro 48in Zero Turn Commercial Mower (A51691)
2017 Snapper Pro...
MI-T-M PRESSURE WASHER (A52472)
MI-T-M PRESSURE...
