CK20HST Relief Valve
   / CK20HST Relief Valve #1
mackroyd
CK20HST - Wont go uphill - goes into relief
Hi Guys,
Bought a second-hand 2004 ck20 HST with 200 hrs on it. Ive put 100 hours on it and in that time noticed both its a brilliant little tractor, and the HST goes into relief a bit too easily - it wont make it up a slope on my property. I had the dealer come out who tested the forward and reverse relief valves which went into relief @ 3200PSI. Dealer said this was in spec, although I have seen much higher figures quoted on this site? He also tested the charge pressure, which was apparently half what it was supposed to be. I was later advised the only remedy was to replace the HST unit as a whole.
I was thinking I might take the relief valves out and swap them, or shim them - does anyone know where they are located on the ck20? is it part of the test port below the 3pt speed knob? I know this issue has come up a few times on this site, to which my symptoms seem awfully similar, except for the low charge pressure. What should I do if anything about the charge pressure?
Thanks for any help!
Polaris ATV (A50324)
2010 Lincoln MKS (A50324)
2010 Lincoln MKS...
Swict 78" Bucket (A50121)
Swict 78" Bucket...
2023 FORD TRANSIT CARGO VAN (A52141)
2023 FORD TRANSIT...
2018 New Holland TS6.120 4WD 96HP Agricultural Tractor (A50322)
2018 New Holland...
3001 (A51691)
3001 (A51691)
