Backhoe ck20hst front wheel drive shaft fell out
   / ck20hst front wheel drive shaft fell out #1
twade
Has anyone ever heard of the spline that drives the front wheel
coming apart? It appears to be pressed together, it came right apart
at the wheel. Splice appears to be fine. What to do now, take wheel and
and assembly to dealer to get new. Can you get orings and repress
back in? Thanks Tim
   / ck20hst front wheel drive shaft fell out #2
A picture would help a bunch
If a new machine then have repaired under warranty
Joel
   / ck20hst front wheel drive shaft fell out #3
A picture would be real good/helpful.
Sounds to me (from your description) the axle came completely out of the hub - tire still mounted(?). If it did one or both of the snap ring clips that hold it in place are broken.
If your tractor is fairly new, I would take back to your local dealer and have them repair under warranty if applicable.
Tony
(APPROX 24) 2" X 3" X 39" THICK TUBING (A51247)
(APPROX 24) 2" X...
T3 Motion Patroller Segway (A51694)
T3 Motion...
2012 Morooka MST1500 Crawler Carrier (A52384)
2012 Morooka...
2021 VemaTEC 30in Excavator Bucket (A51691)
2021 VemaTEC 30in...
UNUSED JCT 72" HD BRUSH CUTTER (A51248)
UNUSED JCT 72" HD...
Lot of 2 Loader Tires (A51691)
Lot of 2 Loader...
