CK20 Running hot
/ CK20 Running hot #41
Screens and radiator have been cleaned ( removed battery shop vac-ed out all debris, blew out radiator with med-pressure air from fan side) coolant looks clean, no oily residue, no bubbles and is topped up. Hood screens are free of debris and air filter has been replaced. Oil has been changed recently, topped up and no froth or any detectable abnormality. Could the pto be bound up somehow so that the tractor is working too hard to turn it?
Ok, I thought you had, but couldn't remember. Have you checked under the mower for something wrapped around the spindles? Also, does the tractor overheat when you just use it for loader work or such? If it's a PTO problem inside, then it's a major issue.
/ CK20 Running hot #42
I recently purchased a used (obviously) 2006 CK20 with 330 hours on it. I bought it to do a variety of jobs, mowing being the most common. To do the mowing I got a 60" Bush Hog finish mower. The trouble I'm having is that after about twenty to thirty minutes of work (mowing fields, 6"-8" grass) the tractor starts to run pretty hot. The gauge gets up to about 1/3 between the middle and the red and stays there. I have checked the coolant and oil levels, they are both fine.
It may be running hot simply because you are running a 60" finish mower, cutting 6"-8" field grass with only 17 PTO HP.
/ CK20 Running hot
Could be. Although the owners manual says it should run A 60" finish mower, and there are reports on this forum of the same machine running a 72" mower with no problem. I bought the mower from a fellow who was running it with his 25 yr. old 19hp Yanmar (don't know what the pto hp was). And, I have the same problem when the grass is short.
/ CK20 Running hot #45
One way to know for sure is to flush the coolant, install new, and change out the thermostat at the same time.
Your tractor may have a problem with it's T-stat or something more serious like a head gasket issue that hasn't quite manifested itself yet. Tractors are sometimes like people. One may be able to run the mower, and another might not.
You won't know for sure until you change the symptoms, if they follow the work you do then you're onto something. If not, well, you'll have to deal with the outcome then. One thing is for sure if it were me, I would not continue running it as it is right now. JMHO.
/ CK20 Running hot #46
rule of thumb is 5 hp per foot of mower. Just spinning it without cutting takes hp.
Based on that 'rule' you're over loading your machine by about 40%.
/ CK20 Running hot
So you're saying this tractor should only run a 40" mower?
/ CK20 Running hot
I think that's good advice. I'll let you know how it turns out.
/ CK20 Running hot #49
You have eliminated just about everything but the thermostat......for petes sake, go to Advance Auto or Auto Zone and buy a Stant.....it cost me $8.08 to do this to my CK30. By the way, factory thermostat was a 160*, replaced with 180*, temp gauge runs right between the two normal marks, oil temp runs 180* even after 3 hours of mowing on an 80 plus degree day, with a 73" flail mower.
/ CK20 Running hot
I ordered a thermostat from Tractor Joes, but, after more than a week they still haven't sent it. I'd love to to just get one at Autozone, any idea how to find the right part number? I've been looking on the internet, so far I can't find a cross reference.
/ CK20 Running hot #51
And it's over heating by about 40%. Reasonable. There's a difference between what a tractor will do and what it will do comfortably.
/ CK20 Running hot #52
my Cub Cadet lawn tractor has a 46 inch cut and has 22 hp, and a lot less weight to carry.
I know the diesel has much more torque but Cub put a 22 hp engine in it for a reason.
/ CK20 Running hot
My understanding is that "5hp per foot rule" applies to rotary cutters (brush hogs) not to finish mowers. This is why Kioti specifies that the CK20 will run a 60" finish mower, but, only a 48" rotary cutter. There is also considerable anecdotal evidence that tractors of this size can (and do) run mowers of this size without difficulty. Anyway, my point is, I don't think that's the problem. Anybody know of a cross reference for Kioti thermostat part #"s?
/ CK20 Running hot #54
Where do you see the Kioti specification for that?
I suppose in low range only you would be fine but I know from personal experience that a CK 20 will labour with a 5' finish mower in high range on anything but flat ground and one week of growth.
/ CK20 Running hot #55
Hey Swede....I don't know about a cross reference, but I did find something on Tractor Joe's site. The part number listed here, is for a CK30, and I know your CK20 thermostat part number is different, but if you look at all the applications of this replacement part, you will see the CK20 listed. When I replaced my CK30's thermostat, I bought a Stant #13848 (180*). So if this linked page is correct, and that thermostat will work in all of the listed tractor models, the Stant number I mentioned will also.
E5800-73011 - Thermostat for Kioti | TractorJoe.com
/ CK20 Running hot
Specification is in the owners manual.
/ CK20 Running hot
Hey Swede....I don't know about a cross reference, but I did find something on Tractor Joe's site. The part number listed is for a CK30, and I know your CK20 thermostat part number is different, but if you look at all the applications of this replacement part, you will see the CK20 listed. When I replaced my CK30's thermostat, I bought a Stant #13848 (180*). So if this linked page is correct, and that thermostat will work in all of the listed tractor models, the Stant number I mentioned will also.
That is a huge help. Thanks very much, I appreciate it.
/ CK20 Running hot #58
Hey Swede, It just occurred to me that you may not know about free online parts catalogs for Kioti tractors. I use the one from MIE but several other dealers host them too. The part numbers are all the same but different dealers have their own prices. From the entry page, use the look-up by model on the left side (the quick look-up on the right side seldom works. I don't know the exact year/model of your CK20 but here's a link to the page for the thermostat for a plain Jane CK20.
2016 Ford F-150 Crew Cab Pickup Truck (A59228)
2016 Ford F-150...
2015 Chevrolet Express 2500 Passenger Van (A61568)
2015 Chevrolet...
2017 New Holland T4.110 Cab 4WD w/ 655TL Loader – 1,619 hrs – Excellent Condition
2017 New Holland...
MULTIQUIP LIGHT TOWER (A60736)
MULTIQUIP LIGHT...
2008 FORD F-550 SUPER DUTY (A60736)
2008 FORD F-550...
2005 HINO 268 S/A DUMP TRUCK (A59906)
2005 HINO 268 S/A...
