CK20 rims/tires on DK45S
   / CK20 rims/tires on DK45S #1
ON84
Bronze Member
Ontario
Kioti DK45S Massey GC1705 JD-L120 JD-LA165
My dealer damaged the front tires on my 2007 DK45S (long story). I sent a couple messages to Kioti, and he is now offering to replace them with the rear rims and tires from a CK20. He claims they are identical.
Does anyone know if the rear rims and tires from a CK20 are identical to those on the front of a DK45S? My first guess is that Kioti would match stronger rims and tires with a bigger tractor...
   / CK20 rims/tires on DK45S #2
CK20: ------------------------------DK45S:
Ag1 4WD Front 6 - 12/4 -------------------Ag1 4WD Front 9.5 -16/6
Ag1 4WD Rear 9.5 - 16/6 ------------------Ag1 4WD Rear 14.9 - 24/6
Ag2 4WD Front N/A -----------------------Ag2 4WD Front N/A
Ag2 4WD Rear N/A ------------------------Ag2 4WD Rear N/A
Turf1 4WD Front 23 x 8.50 -12/4 ----------Turf1 4WD Front 29 x 12.5 x15/4
Turf1 4WD Rear 33 x 12.5 - 16.5 -----------Turf1 4WD Rear 21.5L x 16.1/4
Turf2 4WD Front N/A ----------------------Turf2 4WD Front N/A
Turf2 4WD Rear 33 x 12.5 - 16.5 -----------Turf2 4WD Rear N/A
Ind1 4WD Front 23 x 8.50 - 12/4 -----------Ind1 4WD Front 12 x 16.5/6
Ind1 4WD Rear 12 - 16.5 -------------------Ind1 4WD Rear 17.5L x 24/8
Ind2 4WD Front N/A -----------------------Ind2 4WD Front N/A
Ind2 4WD Rear N/A ------------------------Ind2 4WD Rear N/A
This is copy and pasted right from the Kioti website.
KIOTI HOMEPAGE
KIOTI HOMEPAGE
Derek;
Thanks for this. I guess I should have provided more information. Before starting this thread I checked Kioti's site and saw (as you did) that the tire size was a match, but I was not able to determine if the rim (gauge of metal, bolt pattern..) and tire (number of plys, load ratings...)were the same.
I followed your PICs link (great pictures), and it appears that the rim is not the same. In fact, I doubt if it will even fit on the 45. I may drive to another dealer and ask them to lookup part numbers for me.
Thanks.
Art
   / CK20 rims/tires on DK45S #4
If your dealer is proposing to switch the tires to your original DK45s rims then if the tires are a match I don't see any problem.
   / CK20 rims/tires on DK45S #5
The dealer is just trying to get off easy.
They are not the same wheel. My CK20 does not have any protection around the valve stem.
You want NEW tires on YOUR rims.
However the dealer does it, as long as you get the right tires.
Jim
   / CK20 rims/tires on DK45S #7
The standard KIOTI 4 year warranty would still apply to the drive train. I don't see why there would be an issue. Am I missing something?
   / CK20 rims/tires on DK45S #8
What? You don't recognize Neil when he's in troll mode? I think he came out of hibernation when the Bobcat/Kioti deal was announced. He'll get over it.
His point regarding the warranty is moot but I agree with him if his point is that the dealer in this case is being a slime puppy. No good dealer (including Neil) would play this game with the tires. The mechanic screwed up. Period. Replace the tires with factory fresh new ones.
JOHN DEERE 661R LOT NUMBER 106 (A53084)
JOHN DEERE 661R...
2014 Ford Taurus SE Sedan (A51694)
2014 Ford Taurus...
2025 New/Unused Wolverine Vibratory Roller (A51573)
2025 New/Unused...
New/Unused CFG Industrial MX15 RX Mini Excavator (A51573)
New/Unused CFG...
2004 Ford Taurus SE Sedan (A51694)
2004 Ford Taurus...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A51692)
2021 International...
