ck20 problems
   / ck20 problems #1
jtpilch
North Ga
Kioti CK20 , JD1025R
After having the bh off for about 2 weeks, when I hooked it back up the a+b seletor will not stay in the selection a or b. It springs back to the netral pos. Now if you hold it in the b selection the hydrolics work for the bh. with no bogging or anything. not sure what that is. Also my fel is leaking hydro fluid from the brass colored fitting or elbo on right side fel. Any Ideas??
   / ck20 problems #2
The rear hydraulic valve has a detent body on the valve. It sounds like the detent spring is bad.
The loader leak sounds like a loose fitting.
Contact your dealer about both issues.
Ingersol Rand 100 Air Compressor (A50774)
Ingersol Rand 100...
10' Feed Bunk (A50515)
199049 (A51243)
199049 (A51243)
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
John Deere 7130 (A50120)
John Deere 7130...
Lull Highlander 1044C-54 Series II 10,000LB 4x4 Rough Terrain Telehandler (A50322)
Lull Highlander...
