CK20 hydraulics just quit
   / CK20 hydraulics just quit #1
Skippinsd
Rose Hill, MS
Kioti CK20 (2006)
Help please! My CK20 hydraulics just quit - no noise/warning/slow down/nothing...just quit. Have not had any problems to date and while simply pushing some small stuff into burn pile my hydraulics quit working. I checked my lines and fluid -all good. I was told it was probably pump went out so I took that off - it appears fine. How can I figure out whats wrong and fix it?
   / CK20 hydraulics just quit #2
OK, I'll start. I know you said there was no noise, but, do you hear any noises at all when attempting to lift the front end loader? Does your power steering still work? and does the 3 pt hitch still go up and down?
   / CK20 hydraulics just quit #3
If you have no hydraulics, Power Steering, 3-Point Hitch, Loader....remove the injection pump and inspect the fuel camshaft. The hydraulic pump is driven off the back side of the fuel camshaft. Make sure the shaft is not failed and that the pump spins when the engine is turned over.
Hope this helps
Thank you both! The answer was no to all 3 questions so I shall be checking what you said and get back to y誕ll.
   / CK20 hydraulics just quit #5
hey guys , I have almost same issue. what was the end result??
It was EXACTLY what Michigan Iron n Equip said: my fuel camshaft broke...ordered all the parts from them n tractor back to running!!!! $618 in parts n we did all the work ourselves
   / CK20 hydraulics just quit #7
that's great, trying to figure my issue. look at my post is it same issues you had??
   / CK20 hydraulics just quit #8
Thanks for the update...glad you had a happy ending..:D
Yes all same symptoms. It wasnt hard to take everything apart or put back together but you better be mechanical lol. Our shaft was literally broke in half but holding together by pressure. Guess I went over bump n that was that. But a manual! Then start taking apart but take pics EVERY step so you put back easier. Also HINT: mark the teeth with something so they go back exactly. We had to take apart that section 2x cause we were off n you can NOT be off. Michigan Iron n Equip has best prices n service for parts n help!!!! Good luck!
Couldn稚 have done it without everyone痴 help! Thanks all!!!
2019 Ford F-150 XL (A50120)
2019 Ford F-150 XL...
PLEASE VIEW ALL PICTURES!! (A50774)
PLEASE VIEW ALL...
KJ U-Type Shackles (A50121)
KJ U-Type Shackles...
2009 Freightliner B2 School Bus (A51692)
2009 Freightliner...
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
1999 Ford F450 Dump / Plow Truck (A50514)
1999 Ford F450...
